So this will be my first build. My budget is maxed and I can't afford anything more expensive. I want to know your opinion about this thing and perhaps even reduce this amount of $$$. I still hope to see sugestions with AM3+ Cpu socket and any gigabyte gpu. I realy like those gpu's :)
Link: http://pcpartpicker.com/p/KP6p
Sincerely thanking all of you mates who will help me ;)
The GTX 560Ti in Miskonius's build isn't a bad choice. They are good value for money now that the 6xx series are out. I use one at the moment and I haven't found anything I can't run on high textures at 1080p.
I would disagree on the quad Piledriver though - if you are going to build a new rig I would try to future proof a little more by sticking to the FX-6300.
If you must go with Gigabyte, which I can certainly understand brand choices, then what you've got is the best you can get for that budget from that brand.
Thx for help all of you ;). But I just realized, that I'll get f**kin insane taxes in my country, if I want to buy all of parts online, so video card is way over my limit. I thought about same version card just 1 Gb memory and manufacturer of Gigabyte, not sapphire. It's already same just 20$ cheaper, isn't it? So I think this will be the final adjustments for my new pc :) Again, thx all of you ;)
