First build
What do you guys think of my build, any suggestions?
http://nz.pcpartpicker.com/p/CA2Q
Here's a build I recently got from computer lounge:
-Intel Core i5 3570K Ivy Bridge 3.40GHz 6MB 95W LGA1155
-Asrock Z77 Extreme4 Intel Z77 Motherboard
-Mushkin Blackline FrostByte 996995 8GB (2x4GB) DDR3-1600
-ASUS BC-12B1ST 12X Blu-Ray Combo
-Intel 520 Series 120GB 6GB/s 34nm SSD SATA3
-Western Digital Caviar Blue WD10EZEX 1TB 64MB SATA3
-EVGA nVidia GeForce GTX660 Ti FTW Signature 2
-Corsair Vengeance C70 Mid-Tower Case (Gunmetal Black)
-Corsair HX1050 1050W Modular PSU 80PLUS Silver
I built that for around $1900 but given your budget I'd put a 670 and a H100i in there aswell (power supply was a special deal they don't do it anymore so just get a 700w or something) and 16gb of ram is pretty overkill but if you can afford by all means do it.
I literally just bought the p280 today, there are no stock intakes but the case is THE SHIT. Pickup a dualpack of Af120 quiet editions.
Great build btw, no bottlenecks, great parts, i don't know what's fair in nz dollars but this will last you a while.
Nothing's fair unfortunately for example in NZ this is $778 and in the US it is $469. Now given the exchange rate of 1.19 it should cost $561 + whatever it costs to ship it here. I know it doesn't cost $217 that's for sure.
If I had that amount of money, my build would be wayy different.
Im thinking of importing things from ncix, they do international shipping, and im pretty sure i can get things cheaper, either that or an Australian site,
I don't think NCIX ships to NZ but I may be wrong.
Will the H100(i) fit in the p280?
I assume so based on these pictures.
 http://www.overclockers.co.uk/popup_image.php?prodid=CA-168-AN&imgID=2
http://forums.overclockers.co.uk/showpost.php?p=20919557&postcount=86
It gives me the option to add a credit card from new zealand so i think it does
