First Build
First build for now eventually will upgrade in time .Rig will be used for some gaming and some video work, rendering/processing.
Also totals to bit under 800$
Could you guys check and make sure theres no conflicts :3?
Case
Mobo
CPU
GPU
Mem
Storage
PSU
Might spend a bit more to add on a SSD.
Some tips would be appreciated also.
this will be a bit faster at editing, better airflow on the case, better mobo, $15 newegg card for something nice, and a 8GB SDcard
Thanks, also saves 50$. Ill look into it.
Actually 30$ over, still good though.
Yeah, Giga's build is nice, especially with that 3570K in there. You'll be able to overclock with that CPU.
Wouldn't I need a better heatsink then the stock one?
yeah but you can upgrade that down the road
