First build would like some input
this rig will be soly for gamming/media, if anything is misspelled my browser cant spell check for some reason so sorry in advance ^^
Motherbord: G452-1042 ::GIGABYTE GA-990FXA-UD3 AMD 9 Series Motherboard
CPU: A79-8351 ::AMD FD6300WMHkBOX FX-6300 Six-Core 3.5GHz AM3+ Processor
RAM: P33-6301 ::Patriot Viper 3 Extreme Performance Black Mamba PV38G160C9K 8GB Memory Module Kit
PSU: U12-41563 ::Ultra X4 Modular 850-Watt ATX Power Supply V2 - 850W, i realy like this one cause of the life time warenmty
CASE: D15-8950 ::DIABLOTEK Gamer Series CPA-8950 Cyclops ATX MID Tower i do like this case 5 fans come with and room for a fan controll panle, would like some input on this case if its worth it or should i get a differant one.
HDD: A208-5200 ::ADATA Premier Pro SP600 32GB Solid State Drive - 2.5" Form Factor, SATA III 6 Gb/s,for OS only i have a larger mech HDD for storage
graphics card i have no idea what i want to get ideas would be greatly apreciated budget for graphics card is around 140$
140 dollar is realy tight for a good gpu that fits into the specs of youres build, i if may advice you try to look if you can safe some money on some parts, like maybe a cheaper case and a cheaper psu, A 750W 80+bronze. try to safe about 100 dollar, and buy a 7870XT  from shapire or club 3D joker. or a normal 7870, but  if you can afford it a 7870XT is the one to go.
grtz Angel ☺
That PSU is overkill by a long shot. Buy a cheaper one and use the extra money to bolster your GPU budget. Don't worry about the lifetime warranty - who keeps a PSU for a lifetime? I've had the same cheapo 80+ PSU for about four years and had no issues.
If you want lifetime waranty get evga or pc power an cooling they last forever
the case im getting is 79$ so its cheap ill switch to a 750 watt PSU.
and ill either go with the 7870 or the 7870XT
ty for the input ^^
ty for the input ^^
No problem, evga stands behind their products, they view their customers as people not things to rip off
