First build What am I doing
Hello all
 So I have decided to build my first PC, so i have been looking at parts and well here is what i got so far http://pcpartpicker.com/p/Jc3U The case mother board and cooler im good with the other parts well... there are just so mine parts to choose from i can not decide. any tips or is it good the way it is .
This is my first PC build so is there the only thing ells i need other then a screw driver
Thanks for your help
What are you going to be using it for?
gaming mostly and a little video editing
Your first build was alright, but this one will give you a little more bang for your buck
http://pcpartpicker.com/p/K7PR
Going along with anarmypig's suggestion, the BitFenix Survivor mid-atx case may allow for a 'flashier' build. I own one myself for a secondary 3570k based rig, and the build quality, airflow and cable management is stupendous.
http://bit.ly/12ZMYqo
