First Build - Thoughts?
Hey,
I got my last PC built for me but want to build my next one myself. I'll be using it for gaming and streaming. I know all of these parts are compatible and the build should be able to take every game I throw at it at high settings but I just wanted another opinion. Is this too complex for my first build? Am I spending more than I have to to get this performance? Also, I live in England and wanted to spend under £1500.
http://uk.pcpartpicker.com/user/Willgasmic/saved/Pb6mP6
Cheers!
Why not a z97 other than that its pretty solid but the psu is a bit overkill. Really if your JUST GAMING personally i would save some and go i5 as i7 are normally better for productivity and wont give that much of a boost in games but if you have it and want to spend it why not :) I take it you have an os aswell. If you go with an i5 i would say look at spending money on a better gpu. Just check benchmarks because i hear everywhere that the 780ti is still outperforming the 970 and 980 in some games when they are benchmarked, However i would recommend looking at the 980
For streaming if you want to save $$ or allocate it to somewhere else in the build here are my suggestions.
An AMD 8350 is pretty cheap and is excellent for streaming. I've got one myself and I really can't justify upgrading to an i7 and it's not even overclocked. If you're worried about temps I've got an h90 on my and with 24 celcius ambient I've never seen it go above 60 and browsing internet its around 32.  An i7 for streaming and gaming is serious overkill.
A 550-750 watt power supply would be fine in your build.
The cooler will come with thermal paste pre-applied so you don't need to buy that.
Thanks for the replies! I've changed the PSU, CPU, GPU, MOBO and removed the thermal paste as you said it already comes applied on the H100i. This is now roughly £200 cheaper, even though I upgraded to a 980!
What about the 9590 its no that much more http://uk.pcpartpicker.com/p/FxnXZL
Obviously it can be subbed for an 8350
Its a good build but the one i linkes is cheaper and has a better cpu however the 9590 gets extremely hot so id recommend picking up some good case fans to help cool.
I didn't know if it was worth the extra money? I saw Tek Syndicate's video on it and Logan said he was unsure about it?
I don't think the 9590 would be worth it for me.
http://uk.pcpartpicker.com/user/Willgasmic/saved/xHZrxr - This is a cheaper build I've just put together.
 Also, I went on CyberPower (where I got my last gaming rig) and done something around the same price with near the same specs including next day building. Thoughts?
CAS:Corsair Obsidian Series 450D Mid Tower Gaming Case w/ USB 3.0 & Full Side-Panel Window
CPU:AMD FX-8350 4.00 GHz Eight-Core AM3+ CPU 8MB L2 Cache & Turbo Core Technology *** Overclocking S&S *** [-17]
CS_FAN:Default Case Fan
FAN:Corsair Hydro Series H55 Quiet Liquid Cooling system w/ 120mm Radiator (Corsair CPU Water Cooling ***Overclockable XXX***)
HDD:120GB Samsung 840 EVO SATA III Gaming MLC Solid State Disk [-1] (Single Drive)
HDD2:1TB WD Black WD1003FZEX SATA-III 6.0Gb/s Cache 7200RPM Hard Drive [+60] (Single Hard Drive)
MEMORY:16GB (2x8GB) DDR3/1600mhz Dual Channel Memory (HyperX Blu w/Heat Spreader)
MOTHERBOARD:ASUS M5A99X EVO R2.0 AMD 990X Chipset, CrossFire / SLI supported, ATX Mainboard w/ 4 RAM slots, 7.1 Audio, GbLAN,USB3.0, SATA-III /s, RAID, ***Overclockable XXX*** [+17]
NETWORK:ONBOARD 10/1000 NETWORK CARD
OS:Microsoft® Windows 8.1 (64-bit Edition)
POWERSUPPLY:850 Watts Power Supplies [+39] (Corsair 850 Watts RM850 80 Plus Gold Gaming Power Supply - Triple SLI Ready [-2])
PRO_WIRING1:Professional Wiring for All WIRING Inside The System Chasis - Minimize Cable Exposure, Maximize Airflow in Your System [+19]
PRO_WIRING2:Ultra Enhanced Packaging Solution Mid Tower - Protect Your Dream System During Transit [+14]
RUSH:Fast Track Service !!!  Ready to Ship in Next Day with no Overclocking Service [+59]
SOUND:HIGH DEFINITION ON-BOARD 7.1 AUDIO
VIDEO:AMD Radeon R9 290X 4GB 16X PCIe Video Card (Single Card)
WARRANTY:DESKTOP STANDARD WARRANTY: 3 Year Labour, 2 Year Parts, 1 Month Collect and Return plus Life-Time Technical Support
Price: £1,079.00
imo the AMD CPUs are good, but at this price range you can do better with Intel's higher single core performance.
http://uk.pcpartpicker.com/p/2hMmBm
Room for another 970 in the future as well.
I saw temperature improvements of around 3 degrees when i swapped my pre-applied thermal paste on my H100i with arctic silver 5
I have an i5 3570 in my current set up, would the 4690k be much of an upgrade? Also, how are XFX PSUs?
