First build. Ready to order! Leaving consoles
Tek syndicate has helped me a lot with this build. I've also tried to do a lot of research. I'm opting to build this instead of getting a PS4 because I feel more inclined to go towards something that can give me productivity outside of gaming. I just wanted some of you evaluate this before I go ahead and order. Is there anything that can be improved without compromising quality? I included peripherals as a cost ($900 altogether)
http://pcpartpicker.com/p/1Oi8D
I would recommend a higher wattage power supply and something a little stronger than the cx series. On a lower end system yes that is good, but if you ever wanna upgrade your gonna want a bigger beefier power supply.
thanks for responding. I've been told to get a bigger PSU as a suggestion from other sites too. Maybe I'll go for the 600W.
