I have no idea how to add the part picker.
To make things easier around here just include some extra info so we can tailor you better.
•Budget. How much are you willing to spend?
Upto $1500
•Where do you live (what country, don't post specific details), and what currency do you use?
The you-saw (USA), beef currency, well USDA but with out the A
•Is there a retailer you prefer?
Nope, as long as they have good prices and dont test on animals =D.
•Do you need or already have peripherals? (this can add to costs)
No idea what this is, honesty right? But now I know. Mechanical, not sure whoch ones, I gotta watch the types again, as for the mouse no idea,
•What will you be using your Glorious computer for? Gaming? Rendering? Mix of both? Or is this a home media PC or Steam Box?
Mix of the four, game, render, home and some steam
•Do you overclock or want to get into overclocking?
All in do time, but i'm a person to want it when I need it. What if I master the OC book in 5 minutes, then I need to buy a higher tier product?
•Do you plan on going for custom water-cooling now, or in the future?
Hmm, maybe in the future, With higher power comes uhh more fluid less air (shrugs and laughs)
•Operating System. Do you need a new one?
Yas, thinking between Windows and Linux, (que thinking theme)
Intel i5 4th gen 4690k Devils canyon 4 threads, up to 3.9GHz, turbo boost 2.0, 88w for 239.99
MSI Z97a SLI Krait edition,139.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130862&cm_re=msi_z97a_sli_krait_edition-_-13-130-862-_-Product
GPU, MSI GTX 970 4GD5T OC 256bit
Core clock 1102mhz, boost clock 1241mhz 339.99
or
Core clock 1140, boost 1279 348.99
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100007709 50001312 600536049&Manufactory=1312
Evga 220 G2 0750 XR 80 Plus Gold 750w, single rail, (12v), ECO mode, 129.99
or
Evga 120 G1 0750 xr 80 plus Gold 750w quad rail (12v), 104.99
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007657 600014094 50001402 600315663&IsNodeId=1&cm_sp=Cat-PowerSupplies_2--PopBrand--EVGA
Corsair Vengance pro 16gb 2x8, DDR3, 240 pin, 2133
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007611 50001459 600006072 600006050 600564639 &IsNodeId=1&Description=ram%2016gb&Order=BESTMATCH
The second 970 is better for OC, plus it has higher mhz out the box (gameing edition), for the psu, ive read both sides ( what to do what to do).
For SSD I was thinking the Samsung 850 evo mz, 250gb, 107.99
or Kingston SSDNow v300 240gb 87.99
http://www.newegg.com/Product/ProductList.aspx?Submit=Property&Subcategory=636&N=100008120 600076738 600038496 600038500 600038485 600038487 600038488 600038463&IsNodeId=1&IsPowerSearch=1&cm_sp=CAT-SSD_9--VisNav--UpTo256GB
Hmm looks like the black series from WD is made for gaming and editing, 2tb for 121.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236624
So far this is what i've been looking at, still need to look at cases (any ideas?), plus any input would be of great help.
A bit to know facts.
This will be for light to mid gaming 2/10, video editing 8/10, BUT once I start to game on it i'm sure the console with rest for a while.
First build too.
(Shaw-sha-sha)
