First Build Problem
I just finished putting everything together on my first build. When I turn the PC on everything seems to be working fine except there is no video signal when it is plugged into the monitor. Any ideas on what may have caused this and any solution?
what are your system specifications?
are you using onboard video? or a dedicated video card? is your monitor on?
if its an AMD FX-xxxx cpu you most likely need a BIOS update!
