First Build. Please Help
I'm planning on building my first PC and was wondering if you guys could check it out before I order the parts. I'm open to any feedback and/or compatibility issues. Thanks.
http://pcpartpicker.com/p/2Zv2M
GPU: EVGA 03G-P4-3784-KR GeForce GTX 780 3GB 384-bit GDDR5 PCI Express 3.0 SLI Support
CPU: Intel Core i5-4670 Haswell 3.4GHz LGA 1150 84W Quad-Core Desktop Processor Intel HD Graphics BX80646I54670
Motherboard: MSI Z87-GD65 Gaming LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Extreme OC High Performance Triple CFX/ SLI Intel Motherboard
RAM: G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL10D-16GBXL
HDD: Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive
SSD: SAMSUNG 840 EVO MZ-7TE250BW 2.5" 250GB SATA 6Gb/s MLC Internal Solid State Drive (SSD)
Power Supply: CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC
Case: CM Storm Scout 2 Advanced - Gaming Mid Tower Computer Case with Carrying Handle and Windowed Side Panel - Black
I like it, but the shopping cart won't show us all the parts in there. If you want to save some money, I'd go with 8GB of ram personally, unless you plan on doing some video editing. Other than that everything looks good, very nice selection on the GPU as well.
The motherboard seems a little overkill unless you plan on going sli down the road and if you always plan on running  just one card.  I would say you could easily go to a micro atx and save a few bucks and lose nothing in terms of features that you would utilize, also would consider not going z87 if you're not buying an unlocked (k) processor.  The power supply is a little over the top as well as a 750w should be able to able two 780s in your rig.  Also if you only plan on gaming at 1080p the 770 is a better choice since if you game on 60hz monitor you will see no difference really between the two cards.
Would this be better as far as RAM goes?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
I'm not sure if I'll be getting a second GPU in the future, so I'm keeping my options open with my MOBO. I did some research on the micro atx and decided I just can't part with the z87. Thanks for the heads up on the unlocked processor, I switched to the i5-4670K. I'm still trying to decide if I want to down-size to a 650W PSU as the difference is only $20.
Well they do make z87 micro atx boards not sure if i confused you.  Also you're going to have to pick up the k processor and overclock you're going to need an aftermarket cooler just keep that in mind.
I would do this : http://pcpartpicker.com/p/31KhJ
GPU wise, down the road once you need it you can just add a second but for now it will do just fine
CPU wise, It is a very powerful cpu great for multi threaded processes, multitasking and heavy loads, I was going to add a CoolerMaster 240M but pcpartpicker is being stupid and doesn't have it, with that cooler you should get 4.6/4.8 and if its a good one 5.0 Ghz.
RAM: idk, i just like this set :P
SSD: idk, yoou dont need 250GB, 120 is fine for OS and programs, HDD for big files and games.
any specific reason you choose the storm scout 2?  because there are a lot better cases for a lot less, also I notice you don't have a heatsink on the list
Price:$1,379.63
the mouse is pretty decent I'm using it right now
