First build, please help!
 hello everyone!
I want to build my first computer but i'm not completely sure about my choices. could you please check if this will be a good setup?
i want this computer to do fast web browsing, high quality movie playback and i want to play some games on it.
my budget is 600 euros (791 usd). if you have some comments or suggestions please tell me.
CPU: Intel i5-2500k
GPU: Sapphire HD 7770 OC
RAM: 8GB Corsair vengeance DDR3
PSU: Corsair CX500
Motherboard: ASRock B75 Pro3
HDD: Western Digital green 1TB
Case: Corsair Carbide 200R
thank you for your time, and sorry for my bad english. it's not my native language...
Looks like a really nice build. Since you're getting a K-Series processor, you might want to make sure you look into getting an after-market CPU cooler so you can overclock as high as you really want. I recommend the Cooler Master Hyper 212 Plus, Cooler Master Hyper 212 EVO, or NZXT Havik 120. I would have recommended the Havik 140, but it might be a little tall for your case. I can also strongly recommend an SSD to use as your boot drive, but that might not fit into your budget once you factor in the CPU cooler.
Get the i5 3570k It's slighty better but is pretty much the same price.
thank you for replying, i'm not planning to oc the cpu soon. so a ssd as a boot drive may be a good option. do you have any recomandations?
He doesn't need the 3570K (although I love it). The 2500K will be fine for gaming and a bit of video editing. But as you say, their price is pretty similar if you want to go that route. The 2500K is better for overclocking, though (SandyBridge generally better than IvyBridge in this regard).
