I posted before but this is the final version of my first build.. Any advice on wether it is good or not (im kinda new to the pc building community xD)
build:
build:
What will you be using it for? I.E. Gaming, productivity, video editing? What is you budget?
Mostly gaming, budget around 600-700$ US
I really think the r9 270 would be a better buy if you can find it for you price range.
Anything else?
I think that this will game and function much better for you and be a better balanced rig overall.
http://ca.pcpartpicker.com/p/hw84GX
The Cpu and mobo can be OC'ed to be quite fast .... and with the more powerful GPU you will have no problem playing games on high settings @ 1080p.
The SSD system drive will make it snappy and the 2TB seagate is more dependable storage drive than the 3TB drives.
If unsure how to OC ... ask us and we will show you and guide through some tutorials.
Is it really worth it to overclock?
Congrats you have almost literally picked out my system the only part where mine is different is the PSU and the Graphics Card Nice..
Which build are you reffering to?
And I am tempted to put the Azza SIRIUS case instead, because the Enermax has some compatibility issues with the graphics card..?
and I am tempted to put the Azza SIRIUS case instead, because the Enermax has some compatibility issues with the graphics card..?
There is no conflict ... it just says that three hard drive bays out of 9 will be blocked by the GPU
here is an other way you could go ...
That FX 6300 CPU could easily be OC'ed from it's base clock of 3.5Mhz to 4.2Mhz and maybe farther ... and the performance gain would be noticed in some games and many apps.
And then the GPU could get a little OC bump and you will start to feel when it is the sweet spot for each game.
Or here is your build with just a couple changes ... it was a good pick except for the GPU and it will be much faster with the SSD and the 3TB Seagate drives have a very high failure rate.
And this mobo is current gen and will not need a bios update ... and has better power delivery for more stable OCs.
Had to give up some GPU power from the R9 280 down to a R9 270. to keep on budget.
http://ca.pcpartpicker.com/p/gFkgpg
thanks a lot for the help! :)
Would it be possible to change some things so that it costs more around 600-650$ US ?
sure . . here is $734 Canadian should be about $640 USD and will game well ... you will want to add an SSD and another Storage drive next year or ???some time???
http://ca.pcpartpicker.com/p/zmGbdC
Not sure if you checked, but Newegg has most of those parts on sale. The 8350 is 139 and you could always downgrade to the 8320 which is slightly slower for 119. I would check the sales on there before they are gone.
Also, I just got this case but it should work for you as well and save you a few more dollars.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139038
Op lives in Canada
yes, I am planning on improving some parts eventually but right now I just want a basic build. Thanks a lot for the help :)
Just saw that
