First Build(Need Help)
I'm new to this forum. I ride motor vehicles and play allot of old school games. My friend, Kevin told me I should build a p.c but I Do Not Know Anything about the computer world. Kevin give me this account so that I could know how to build and check my p.c. Also my Kevin told me I need a new computer. My budget is $800. thank you
There really are infinite possibilities with that budget. I would recommend researching the topic, or watch some videos on youtube. There are tons of build guides. I'm pretty sure Logan did an 800 dollar build last year. It may be a bit outdated, but you could update it.
People cant just build your PC, what games do you plan on playing, are you going to render videos? Do work on this PC? Be specific!
yea $800 will get you quite a good system but if you are more specific with what you want to do with it the more people can tailor a system build for you
I'm trying to get a PC that works for steam games such as battlefield 3, super mario world and dragon ball z. But I will like to keep it updated as soon as possible. I like to buy auto parts from online stores and do a few bids. I'm doing my research.
I put in an overclockable setup if you want to look into overclocking when the time comes.  It's very, very similar to my setup.  I just don't have the money for the GPU yet :P.  This build is small for convenience.
http://pcpartpicker.com/p/1Lji4
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor.  Haswell has almost nothing to offer desktops and runs hotter.  This will work, and save some money for other places.
MOBO: MSI Z77IA-E53 Mini ITX LGA1155 Motherboard.  Cheapest one with a Z77(overclockable) chipset.  Mine works great.  The wifi antenna is a bit flimsy, though, so be careful with it.
RAM: Kingston Beast 8GB (2 x 4GB) DDR3-1866 Memory.  It's cheap!  Cheaper than all the 1600mhz 2x4gb kits I could find.  Should serve you well.
HDD: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive.  Typical stuff.
GPU: PowerColor Radeon HD 7950 3GB Video Card.  Great price/performance ratio.  Should max out almost all games.
CASE: Fractal Design Node 304 Mini ITX Tower Case.  It's small, it's sleek.  It has a wonderful layout.
PSU: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply.  Rebranded Seasonic(one of the best PSU makers).  I have this, and it was a tad bit hard to manage the cabling.  I stuffed all the extra wires into the second slot in the hard drive bay, and it works nicely now.
Seasonic is just an OEM; their units can be as bad as any other OEMs'. The individual products matter, not the brand name.
Again, here: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=225
But now I see your point.  It's true that it's the actual product that matters.  However, I do believe that ALL of Seasonic's PSUs are one of the highest quality stuff out there.
OK, I'm researching about overclocking.
