- Budget. 800 USD
- I live in the U.S.A. and use the U.S.A.D.
- no preferred retailers
- I have no need for accessories
- I will only need the PC for gaming and using some Microsoft Office
- I will want to overclock just because I understand that helps quite a bit
- I plan to get some water cooling in the future
- No need for OS
- What is Mining BTC? NEWB
If you Game-
- What kind of settings do you like or what FPS do you want to play at? I would like over 60 of course
- What resolution will you be playing at? //or would like to play at? The highest possible not to sound vague and general but it is the truth.
- What kind of games do you like to play? I like my flight sims and fp shooters along with rpgs and rts.
- What specific game will you be playing? Star Citizen, Arma III, Project Reality.
- What type of mouse-grip do you have? Claw
- what kind of games do you play? MMOs and FPS
- Please submit a PcPartpicker list as it's really easy to configure and edit. (you may have to change the URL to your region.)
P.S. please put why I should have one component other another. Cheers.
http://pcpartpicker.com/p/1JQvN
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor. Haswell isn't worth the extra money. An i5 is all you need for gaming.
MOBO: MSI Z77A-G45 Gaming ATX LGA1155 Motherboard. Looks great, allows overclocking.
RAM: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory. Looks great, typical memory from a decent brand. Higher clocked memory makes no difference unless using an iGPU(which you aren't)
HDD: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive. Typical 1TB drive for storage
GPU: Sapphire Radeon HD 7950 3GB Video Card. Great value for the money, and should handle most games with ease.
CASE: Fractal Design Arc Midi R2 (Black) ATX Mid Tower Case. Great airflow, has a window.
PSU: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply. Rebranded Seasonic, one of the best PSU maker.
Bitcoin mining was a way to make money. Forget about it, it's not worth it anymore.
I was under the impression that AMD had greater GPU which meant better for gaming. I'm not being an ungrateful know it all I'm just wondering if you would recommend over a Intel chipset.
Well, AMD GPUs are not the same as AMD CPUs; he recommended an AMD 7950, which is a perfect GPU to get right now for gaming, and an Intel CPU, which is a bit outdated and lacking in comparison to a Haswell CPU from Intel. If you will be playing a lot of games that utilize more than 4 cores, like BF4, for example, then you may want an AMD 8350 8-core CPU. Intel, however, absolutely obliterates AMD at per-core performance, so poorly optimized games that only use one or two cores will be much better off on an Intel system.
Well this paragraph is mighty confusing. brennanriddell helped explain, but here's a little more information for you to feed on :3.
AMD: Makes both CPUs and GPUs. CPUs, core for core, are weaker and hotter than Intels, but are arguably more budget based and their 8-Core CPUs are better for multithreaded applications. GPUs are pretty good and can match Nvidia GPUs for the most part, until the super high end Nvidia GPUs.
Intel: Popular for their CPUs. As stated before, has better single core performance, but is a bit more pricy.
Chipset: Usually referred to the NorthBridge Chipset on a motherboard. This chipset determines the amount of overclocking capability allowed for the system, mainly the CPU.
