First Build: Need help, how is this?
Hi this will be my first build, I have a budget of around $1000 can be a bit more and of course a bit less! I really want to get the most for the money and for it to out of high quality parts. Will be used for some pretty heavy gaming. I don't really plan on overclocking however that is becuase I'm not really sure what it is, will it help considerably? Here are my rough list of part feel free to pick it apart or create something completly new! I will need an OS, monitor and a keyboard. Thanks guys :)
-Intel Core i5-3450 Quad-Core Processor 3.1 GHz 6 MB Cache LGA 1155 - BX80637I53450: $179.99
-MSI LGA1155/Intel Z77/DDR3/CrossFireX/SATA3 and USB 3.0/A and GbE/ATX Motherboard Z77A-G41: $79.99
-Sapphire Raedon HD 7590 3GB Video Card: $279.99
-Corsair Vengeance 8 GB ( 2 x 4 GB ) DDR3 1600 MHz (PC3 12800) 240-Pin DDR3 Memory Kit for Intel Core i3, i5, i7 and AMD Platforms SDRAM CMZ8GX3M2A1600C9: $43.99
-Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive: $69.99
-Crucial 128 GB m4 2.5-Inch Solid State Drive SATA 6Gb/s CT128M4SSD2: $104.58
-Cooler Master HAF 912 Mid Tower Computer Case with High Airflow Design (RC-912-KKN1): $60.24
-Corsair Enthusiast Series 650-Watt 80 Plus Bronze Certified Power Supply Compatible with Intel Core i3, i5, i7 and AMD platforms - TX650: $77.99
-Lite-On LightScribe 24X SATA DVD+/-RW Dual Layer Drive IHAS424-98 - Retail (Black): $24.99
-Windows 7 Home Premium SP1 64bit (Full) System Builder DVD 1 Pack: $91.22
-Asus VH238H 23.0" Monitor: $129.98
-Logitech Call of Duty: MW3 Edition Wired Gaming Keyboard: $27.99
Total: $1170.94
1. Format that list for the love of god
2. I'm going to assume that GPU is a 7950 not a 7590
On that list The only thing I would change is the keyboard but I'm assuming you're just finding the cheapest one you can
I don't know about your future plans but if you ever think you will crossfire I would bump the PSU up to a 750w now.
where did you find all that at those prices? if you can find them at those prices then hats off to you, I'm stumped (rebates don't count)
