Hello everyone, first off, let me thank you for taking the time to read my post, i appreciate it.
So, i'm looking to buy me a pc, something that can handle current gen games, aswell as future ones.
I already own Windows 8 Professional and a 27'' Inch Hp Monitor. All i'm looking for is the PC itself.
Since i've been a console guy my whole life, i don't know much about computers. I've done my research though! I understand how pretty much everything works and know the required parts.
I would love your opinion! So i would greatly appreciate if you could post some builds.
My Budget is around 700$ to 800$.
What i'm mainly looking for to do with this PC is video editing and gaming of course! :)
I was wondering aswell if it's worth waiting till Black Friday or Boxing day to buy the parts, is it?
At last, i just want to say that i live in Canada, so prices might be a little bit higher than USA.
Thanks in advance and i hope y'all have a wonderful day! :)
PS: Could someone enlighten me about the functions of a SSD and HDD?
HDD is a mechanical disk drive. They are used for storage of well everything. Just like how the Xbox 360s have 250 gb models. That is referring to the size of the storage.
SSD is a drive similar but non mechanical. They also store data like the above. An SSD is generally much faster but much smaller. Like in the ballpark of 8-10 times faster at loading data (like when the game loads).
http://ca.pcpartpicker.com/p/1O8T2
Thanks bro! Love the build
http://ca.pcpartpicker.com/p/1OrZK
I assumed you won't be overclocking. A third party cooler isn't needed if you're running at stock speeds.
CPU: Intel Core i5-3570 3.4GHz Quad-Core Processor. The "new" haswell processors run hotter and don't really have much to offer compared to Ivy Bridge, Intel's previous generation of processors. This will do well.
MOBO: MSI B75MA-P45 Micro ATX LGA1155 Motherboard. A motherboard to go along with it.
RAM: Corsair XMS3 8GB (2 x 4GB) DDR3-1600 Memory. Typical ram, enough for gaming.
HDD: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive. This will be your main storage. 1TB is all you really need.
GPU: XFX Radeon HD 7950 3GB Video Card. The new AMD R7 and R9 are basically re-released cards (not counting the 290x). The "old" gen cards are really great value. This should outperform the R9 270x.
CASE: BitFenix Merc Beta (Black) ATX Mid Tower Case. The Core 1000 has sub-par airflow. I prefer this case.
PSU: EVGA 600B 600W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply. A budget power supply with decent quality parts.
OD: Samsung SH-224DB/BEBE DVD/CD Writer. Your typical optical drive if you need it.
The price before rebates and everything (not counting tax) should be under 800. If you can, you can get a SSD and put your Operating System and commonly used programs (e.g. games) on it for super fast boot times. Take a look at one like :http://ca.pcpartpicker.com/part/kingston-internal-hard-drive-sv300s37a120g
Thanks for taking the time to post all of this! Wow! Love it! Thanks again bro! Love the build
