First build! looking for advice
Hey guys! I'll be building a Gaming/editing PC (Mainly for gaming) in the next month for the first time ever. I'd appreciate anyones advice. So here are the parts!
CPU: Intel 3770k (Will OC)
MOBO: ASUS Sabertooth z77
RAM: 16gb of Corsair Vengeance ram (not sure if i should get 1600mhz or 1866mhz.. Would there be a huge difference in performance?)
GPU: I can't decide if I want a 670 or a 680.. Sure the 680 is obviously better, but i heard you can pretty much match a 680's performance with a 670 from just a simple OC? Any opinoins? Also I may put either cards in SLI eventually when I have more funds. (And by the way i play games like BF3, Crysis 3, Arma 3. so ill need a GPU for demanding games like this.)
CPU Cooler: Corsair H100i
HDD: Seagate Barracude 2TB 7200 RPM
SSD: OCZ Vertex 3 120gb SSD (Bootdrive)
PSU: Corsair AX 850w ATX Fully Modular 80+ Gold (And is this beefy enough to handle all of this plus SLI 670's or 680's?)
Case: Corsair Obsidian 650D
OS: Can't decide if I should go for Window's 7 or 8. Any advice?
And there's my list! feel free to add suggestion's. Thanks!
Dylon
I'm pretty much in the same position and decided to go with the 670 since the 680 costs here in Germany about 100-120€ more, but only brings a couple of frames more. Logan even compared the both if I remember right. And yo should get an SSD
Gtx 670 (will match/ beat a 680s "stock" performance when overclocked)
850w psu is fine for any x2 sli
Id go windows 8 and use some software to bring back the start menu (Watch logans review of start8 (edit: linked wrong video lol))
everything else is great : )
Thanks! yea, ill most likely go for a gtx 670. and ill check out that vid logan made. I didnt even see it in my sub box haha. I appreciate your response!
