Ok so i finally saved up to buy new pc
here is what i went with
$119 x 1 corsair sleeved cables
$20 x 1 24 pin corsair sleeved 24 pin cable
$25 x 1 NZXT sleeved led white
$289 x 1 AX 860 corsair psu
$99 x 1 kingston fury 1866 RAM blue 2X4 gig
$99 x 1 kingston fury 1866 RAM white 2x4 gig
$42 x 2 corsair SP fans 120 mm
$22 x 1 corsair AF fan 140 mm
$149 x 1 crucial 240 gb m500 ssd
$ 169 WD black 2 TB mechanical drive
$ 158 NZXT H440 white case
$ 859 EVGA 780 ti superclocked
ok so wanting to know what ppl think of the build to start and and suggestions ( parts are ordered but can change if needed) and for those who notice no CPU waiting on devils canyon in 2 weeks but all other parts ordered
currently on a 1080p monitor but am looking at the 1440p from korea at roughly $400
currently have spare OS and a meka G1 keyboard in white ant the R.A.T contagion
so looking at a black and white theme with blue accents
let me know what you guys think
Hopefully your sticks of RAM are close enough that they will run together with no problems. Sometimes when you mix and match RAM kits(esp over 1600mhz), they aren't really similar enough to run at their rated timings together. You may have to loosen some timings if it doesn't post.
What dollars are your prices in US or AUS cause if its US then DAMN you Aussies get shafted, a 780 ti is only £550 at the most over here. Other than that everything seems fine the RAM should be ok as I have read that its meant to be mixed and matched for aesthetics.
yeah dollars are $AUD and i know we get shafted in Australia ( that's why it took so long to save up ) i just can not wait to try the new devils canyon though and as i don't have any other socket 1150 processors i hope it posts straight away and that i don't have to take the mobo to a shop to flash the bios
That's a nice build, I recently built a rig for a friend using the H440, it really is a fantastic case in all regards, building in it is a breeze.
