So I haven't built a computer in almost forever now and I'm fed up with living off of cheap refurbished laptops (Have not had much money since college loans are OP). My budget is about $450 and that will not increase, I have enough on my plate and I am looking to build this to 1) keep me sane in a period of unemployment and general bad living situation and 2) increase my gaming experience.
I live in the US and already have a monitor, keyboard, mouse, and a spare windows key. I do some odds and ends work for people, Market research and analyzing, and some Photoshop work. As for the gaming end of things; I play some shooters like CS:GO and TF2, some MOBAs like LoL and Dota2, and platformers.
I have talked to some friends who know a bit more than I do, but am looking outside of that to see if what I am looking at would do all that i listed above with some room to upgrade in the future. Here is the List: http://pcpartpicker.com/p/2sP0O
Also note i did just have the case given to me from a friend who accidentally ordered 2 and worked out a deal with me because he was too lazy to return the 2nd one. I appreciate anyone who will take the time to help me with this and remember, that my budget is $450 and that cannot change. Saving up is not an option right now as this is to help keep me sane while I search for full time employment.
The build you put together would be just about perfect for your needs. The only thing I tweaked is to get a little cheaper RAM and use the money towards a six-core CPU. You won't notice a difference between the DDR3-1866 vs the DDR3-1600 that I chose.
Yes, it's a good budget brand. Logan used an A Data SSD in one of his budget gaming builds a while back and had very good things to say about it.
However, after checking the reviews on newegg, I noticed that the one I included is actually out of stock. This set is in stock at newegg or tigerdirect and is only a few bucks more.
mhh ok, might have to see if it goes on sale, like the $450 is firm, my income is very restricted. it may sound silly, but that is my position. Thank you though, I had been trying to find a way to get the FX-6300
So here is a build that obviously is over your budget http://pcpartpicker.com/p/2sZMt but if you take away the GPU you have a build under your budget that can still game quite well. My suggestion would be to wait on the 260x and get one down the line drastically improving your gaming ability. I actually have that motherboard in my system, I've had it for about 6 months, no problems. You could possibly find a cheaper one if you don't plan to overclock. Also it's all from newegg, so you could order it in one big order. Good luck on whatever you decide to do!
I'll keep this one in mind too thanks, I do have one other question. Is Seagate or WD the better route. I have some friends that are split on which route.
I have a WD 1TB drive and 2 Seagate 3TB drives in my current rig. They've all been great so far, and I haven't had negative experiences with either brand.
Great budget build. I think this is more than adequate for your needs. You will be able to upgrade in the future. And a quick budget tip: Buy AMD processors. They are cheap, and pretty much always a steal.
Modular is usually for ease of wiring and cleaner looks. I personally have a non-modular power supply in a tiny Mini ITX case. It's not that bad. I would put modularity as less of a priority if budget was the issue.
Sooo I was just fortunate to be offered a much higher paying job and most of this build I am looking to keep. But as far as the GPU goes, Would this http://pcpartpicker.com/part/msi-video-card-r7260x2gd5oc be good or for that Price or is there a better choice.
For around $140, that R7 260x is a good choice. It's essentially a rebranded HD 7790, which is one step up from the GPU that was in the first build, the 7770.
