Mokoi
August 23, 2013, 12:37pm
1
So I decided to replace my console and get into pc gaming and was wondering if this is a solid first build. http://pcpartpicker.com/p/1vi0E
I basically used the parts logan recommended in a build video just changed the ssd and case also is there a better gpu around the $300-400 price range
The budget I set is $1500 also I wont be doing any editing just gaming
build looks good, i would personaly go for a 128GB SSD, and the money you save i would go with Hasswell i5-4670K with a Decent mobo z87 mobo. like Msi Z87 mpower
this: http://pcpartpicker.com/p/1vjWj
or this: http://pcpartpicker.com/p/1vjXz
grtz Angel ☺
Mokoi
August 23, 2013, 4:23pm
3
Thanks im going to go with the msi Z87 i just really like the colors of the ram and mobo matching
you also have a matching GPU a Msi Nvidia GTX770 Twinfrozer, but that Radeon 7970GHZ edition, is a much better deal ☺
grtz Angel ☺
