I've been researching stuff for my first build for a while and this is what it seems to have come down to. Can you guys tell me if my builds are okay or if you guys recommend anything.
http://pcpartpicker.com/p/pknw
http://pcpartpicker.com/p/pkNZ
the one with the fx, it's too unblanced. get the 6300, and get a mid tower and a cheaper mobo, such as the extreme-series. and maybe even go for an i5-3570k and a normal 7870.
the ghz edition is just pre-oc'd.....
I know the Ghz is just pre Oc'ed and thats fine with me, it's not anymore expensive then the others. And I ask how it's unbalanced?
If I were you I would go for the NZXT Temptest 210. It is great, but it not the lambo of all cases. It is great for saving money though.
I just finished a second build and used the FX6300 CPU. Even Logan recommends it as a great all around CPU. You will have lots of room for expansion with both the case and power supply. I like it.
Thank You! So go with the FX6300 over the FX4300? Check. What about the motherboard, I think that's the main thing I am worried about, it has mixed reviews and I'm just wondering whatcha guys think?
