First build, good for mid-high range gaming?
http://pcpartpicker.com/user/TotalSandwich/saved/DTRYcf this is my first build, and wanted to know of this is good enough to run most games at 60+ fps at high graphics
Note: i already own a gtx 770, thats why i dont have a GPU on the parts list
While there's nothing particularly wrong with the fx line of cpu's, your best bet for gaming is going to be an i5 or even an i3. An i5 will be more expensive, but an i3 will be within the same price range. Right now the majority of games demand better single core performance as they utilize less cores, as opposed to more cores with lesser performance, so while a 6350 may outperform an i3 in productivity related tasks like video rendering (I don't know if it does or not), the i3 can still outperform the 6350 in gaming.
http://www.anandtech.com/show/7963/the-intel-haswell-refresh-review-core-i7-4790-i5-4690-and-i3-4360-tested/2
Here's an anandtech article with the Haswell refresh cpu's with prices. Maybe try the 4350? See how the prices compare, and go look at benchmarks.
Otherwise I guess the build looks good, although you definitely don't need a 750w psu. If you plan to expand in the future, keep it, but it's your choice.
I f you want to see an i5 rig  that is the same price ...the only reason it is over is you did not have a good CPU cooler and this does ...  Total: ...... $721.47   and it will out perform the FX6300 in most games.
http://pcpartpicker.com/user/Ratzzz/saved/L4BzK8
  • CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor
  • CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM
  • Motherboard: MSI Z97 PC MATE ATX LGA1150
  • Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600
  • Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM
  • Case: Fractal Design Define R4 Blackout with Window ATX
  • Power Supply: XFX 650W 80+ Bronze Certified ATX PSU
  • Optical Drive: Asus DRW-24F1ST DVD/CD Writer
  • Operating System: Microsoft Windows 8.1 - 64-bit
  • CM Storm Devastator Wired Gaming Keyboard w/Optical Mouse
  • Razer Electra Essential Gaming & Music Headset Headset
Estimated Wattage:  .... 193W  before adding your GPU
or if you like the Thermaltake brand you can save $15 I usually recommend using either XFX or Seasonic or Corsair for better build quality.
Thermaltake SMART 650W 80+ Bronze Certified ATX Power Supply  .... $39.99
http://pcpartpicker.com/part/thermaltake-power-supply-sp650pcbus
