Hey Dudes! First Post.
So my laptop dies the other week, I figure it's time to upgrade to something serious.
So I want to build a rig for Gaming and video editing, my budget is pretty flexible , but I want to keep it under $3000. I'm not planning on doing any Overclocking as of yet, and I'm going for closed water cooling system for the time being.
System shall be running Windows 8.1
Heavily using Premiere, and after Affects, as well as other suites.
Also wanting to game at 1440p with games such as Fallout, all of the source games. ect..
So, I need some advice, are these parts all compatible? and is there anything you would suggest i changed?
Motherboard: Asus P9X79 WS
CPU: Intel Quad Core i7 4770
GPU: ASUS GeForce GTX 780 DirectCU II OC 3GB (Will add a second Later)
RAM: Kingston HyperX Beast 32GB (4x8GB) Memory Kit 2400MHz DDR3 (Will double Later)
PSU: Corsair 1200W AX-1200 i 80 PLUS Platinum
Heatsink: Corsair Hydro H100i
Extra Cooling: Noctua NF-A14 PWM
Boot Drive: Sandisk Extreme 120GB SSD
Storage: 2 x WD Black 2TB 7200 RPM 64MB
Case:NZXT Phantom 530 Full Tower
Be using through my X-STAR DP2710 1440 Monitor, with an IBM Model M, and a Roccat Kone Pure.
Also be using bulk External Soundcards.
Thanks in advance!
