Hey, I'm trying to get a build together for my friend, and I want some opinions on the build, thanks!
http://pcpartpicker.com/p/1kCGQ
CPU: AMD FX 8350
CPU Cooler: Xigmatek Dark Knight 2
Mobo: Asus Sabertooth 990fx
RAM: 16gb (4x4) XMS3 DDR3-1600
Storage (SSD): A-Data Priemere Pro 128gb
Storage (HDD): Seagate Barrcuda 2 TB 7200 RPM
GPU: Asus DCUII 660ti OC Edition
Case: Fractal Design Arc Midi R2 Mid Tower
PSU: Seasonic 750w Semi-Modular Certified Bronze
OS: Windows Home Premium 32/64 bit
This isn't my first build but my friends, and I wanna make sure he gets more value out of it than my first build :P I am curious to switch the Dark Knight for a 120/140mm waterblock if the temperatures are better.
He isn't set on a NvIDIA GPU, so suggestions for a different GPU with a better price/proformance ratio is appreciated. He is more focused on using this build for gaming so I would appreciate a suggetion for an alternative AMD GPU equivilant to a 660ti/670
I am also leaning toward changing the case to a Corsair Vengance (Green)
Any other suggestions/changes to the build are appreciated.
I apologize if the post is a bit long-ish, thank you everyone have a good day! c:
