First build Editing/Gaming
Hi, im building my first pc very soon. I plan to do a lot of gaming, and a lot of editing. But its not editing that you might expect, its something more like this:
 http://www.youtube.com/watch?v=TU6YEcIAI2A
 Or this, which the song might bring some childhood memories to you guys.
http://www.youtube.com/watch?v=KqDq_tL9pVk
 Its mostly Sony Vegas and After effects. I will definitely get into some 3d in the future, but Vegas and AAE are my primary ones for now. I plan to do a lot of overclocking since i have pretty good cooling. Ill be doing a lot of gaming, probably not on ultra settings since i want good FPS like 100+ while recording, so ill probably play on medium to high with AA turned off. Ill mostly be playing BF4 and Arma3. Ill only be playing at 1080p. As for periphirals, i want to get a wireless headset, but that can come later, same with the keyboard/mouse. I have a headset from my xbox i can use, Turtle beaches X12s i believe, so i can just use that for now. And for KB/M i can just get a cheap combo for like 35$ to hold me off until i get some new stuff. However, for the headset i was planning on getting the Logitech G930, KB the Corsair K70, and mouse, the Func MS-3 Mouse. I dont have a pc, im on a laptop so i havent used a mouse in quite a while, but im more of a mixture between claw and palm, never full one or the other so choosing mice is pretty hard. And for the keyboard, im so used to laptop keys and i havent used mechanical in years so im not sure if i even liked using them. Im so comfortable with membrane, but everyone says mechanicals are so much better. :T Ill also game on my tv, for now, until i get my Benq Xl something, 24 inch 120Hz Ive picked out these specs and i believe they are perfect for me, just want to get some feedback from you guys. Ive already bought the case and have an Windows 7 Ultimate which my brother gave to me.
http://pcpartpicker.com/p/1sItS
Im not sure on the GPU as for now. Since amd is releaseing new ones soon, and BF4 will be bundled with them, but if theyre crap im just going to go with a 770, either gaming or lightning. Although gaming fits my color scheme perfectly, but lightning OCs better for 50$ more. I dont plan to do a lot of OCing the GPUS, just a tiny bit since im new to all this stuff. So yeah. Thats pretty much it. Please leave your feedback on if should change any parts :) (PC PARTPICKER MESSED EVERYTHING UP ON THE POST, SO I JUST LEFT A LINK TO MY BUILD, JUST CLICK IT AND YOULL SEE IT)
That PSU is overkill, and have you considered going intel?
Yeah i know the PSU is overkill, but its for future upgrades i just want to "future proof" it that way at least. Yes i considered going intel, but for the stuff that i am doing im not going to need it. I will upgrade to it in the future, probably when Skylake comes out, or Broadwell. But i dont need it for the editing im going to be doing. Coming from a dual core 2.4Ghz laptop and 4 gigs of ram, the 8350 will be more than perfect for me, especially at the price point.
