First build disaster
ok so I just finished plugging everything in I pressed the power button, get a light for a millisecond then everything goes dead. no idea what is going on  please help me
Post some information on your RIG and we can help you much more efficiently.
Is the CPU power cable plugged in? Should be an 8-pin cable near the top of the motherboard.
ok so now i have power but nothing is showing up on the monitor
What about the power cables to the GPU as well? And what post codes?
no signal from dsub
Give us your rig spec, and everything youve plugged in/ done and then im sure a bunch of us will have a list of things youll need to go check, and then well probably be able to narrow it down.
http://pcpartpicker.com/p/J7S4
ok so that is my list of parts
ive plugged in my sata cables, the motherboard power connecter, all the fans and usbs, the hd audio connector
ive put in my ram, cpu, cpu cooler, wirelessnetwork adapter, gpu, harddrive, disk drive
did you give power to the gpu?
i apologize, i have played around and figured it out thank you
