First build. Advice?
HI everyone, I'm looking into building a PC purely for gaming. I'm from the UK and will probably buy most of the parts from Amazon as there isn't a parts retailer near me that I know of. I don't want to spend over £500 on the system itself, but if there are any suggestions for better parts then I'll have a look.
This is what I've got so far:
http://uk.pcpartpicker.com/p/2HUNi
I already own a keyboard and mouse, 600GB HDD and Windows 7. I would like to play a few older games that I haven't had the chance to play yet such as The Witcher 1 & 2, Skyrim with mods etc. I'll most likely play a couple of next gen games on PC, but I'm not sure how many yet as I've primarily been a console gamer and recently purchased a PS4.
I was looking at around a 21" monitor with 1080p resolution but other than that I don't have a clue what else to look for in a monitor so any help would be appreciated.
Also, I sort of know what overclocking is but I'm not sure about it seeing as though this will be my very first build, so any advice regarding that would be great as well.
I'm looking to buy the parts within the next couple of weeks.
Any advice or suggestions regarding my build would help a lot. Apologies if I missed anything that I need, like I said, I'm new to this.
Thanks.
Looks solid to me. Is there a Craig's List equivalent in the UK? I got my 1080p monitor for only $50 from there. If not, sense there are so many monitors out there, look for top-rated ones in your budget. I know Acer has some good budget monitors out there.
Yeah, we have Gumtree. I'll have a look on there, thanks.
i would spend a bit more money to getting a better mobo, something like an ASUS M5A97 R2.0 for excample, and a CPU cooler, if you don't want a hairdryer. Something like a Coolermaster HYPER 212 evo would give you nice and quiet operation :)
If you got a tv to use now, you could save up to get your preferred monitor later.
On ebay, you can find some good deals. I got a dell s2440l for £107 that is perfectly new but used.
Quick question, will I be able to assemble the parts and turn it on if PcPartPicker is telling me the mobo may require a BIOS update? If not, how would I go about doing said update?
