This will be my first build and my budget is limited to £750. I have spent some time researching all the components that would go into my build and I came up with these two builds:
http://uk.pcpartpicker.com/p/1ObY5
and
http://uk.pcpartpicker.com/p/1ObZf
One is based on intel cpu and the other is based on amd. I will be using this PC mainly for gaming and media (I am planning to do computer science at university next year so this may change). If I was to get the intel cpu I would not overclock it therefore I went with the non k version however with the fx 8320 I would probably OC it to at least 4 Ghz. I would like to play on ultra settings in at least 1080p.
I am looking for a honest opinions on these builds and whether or not the intel or amd cpu will suit me better.
