So here's my progress so far: http://uk.pcpartpicker.com/p/gj6rpg
TLDR; Casual gamer build to last. Anything you would change?
Kind of budget build. Its my first time, so I have lots of questions.
My 5 year old Dell XPSL502x laptop is finally starting to show its age. So I'm going back to a desktop PC, and keeping this old guy for when I need to be portable.
I mainly play CS:GO (1080p) - not too intensive, but I play on pretty low settings and rendering smoke can be slow at the moment. It would be nice to have something more powerful for when I try out new games like Tower Wars, Planetside or Battlefield, so I don't just give up because the game is too jittery - it really takes the fun out of the experience.
I use Photoshop on a weekly basis, so having the SSD, and extra RAM should be nice.
The main idea I try to keep in mind for this build is future proofing - when the next 5 years rolls around, I want to be able to just stick in another 8Gb of RAM, or switch out the CPU.
I would like to be able to over clock the CPU a bit to squeeze out as much performance/£ as possible.
I would also like to have the option to water cool in the future.
The only things I'm unsure about are the motherboard and RAM - I hope you guys can recommend me something.
Rough requirements
Motherboard: USB 3.0 (for front case sockets, and rear), ATX (or micro ATX?), 4 memory slots, max RAM 16Gb+. <£70?
RAM: 8Gb, match motherboard colour? <£70
1. Is there any disadvantage for a micro ATX form factor in my case? Such as will it look strange in an ATX case, will the cooler/ future water cooler fit on. They seem to be cheaper.
2. How much of a difference will lower CAS make?
3. What are the advantages or disadvantages of clock speed in my case?
4. Is the r9 280x overkill, or good for the future?
5. Is it worth getting a FX-8320 instead of a FX-6300. £72 to £104. I think it's unrequired
6. I may need to stick a wireless network card on the mobo too as we don't have wired connection set up yet. Any recommendations? The speed is 170Mb/s on a good day.
7. Anyone had experience with the MSI 970 Gaming motherboard? Being MSI, I am naturally concerned for build quality/stability.
I'm using Amazon.co.uk for pricing because the postage is usually free - so you know what you're paying.
Any improvement suggestions welcome.
Thanks in advance,
Dan
