Hi there fellow PC gamers,
I'm planning on building a $450 - €500 gaming PC, or €370 - €380 in my country. My first list contained the following parts:
Intel Pentium G2120 3.1 GHz Ivy Bridge processor
Asus P8B75-M LX Plus socket 1155 motherboard with 1x SATA-600
XFX Radeon HD 7770 Double Dissipation 1GB
Corsair XMS3 4GB DDR3-1600 mhz (8GB a couple of months later)
Seagate Barracuda 500GB for my games
XFX PRO 550 watt 80+ certified
Cheap-ass Sharkoon MS120 case with two 120mm fans and USB 3.0
Total: €388, or $511
Then I started browsing this forum and noticed other people used Pentium processors for their build and got completely humiliated. People said it was only good for an ultra budget web browsing PC. I don't know if I should agree or not, but anyway.
Then, I made a second list with all the same parts exept with an other processor and motherboard.
AMD Phenom II X4 965 BE
MSI 760GA-P43 (FX), AM3+ socket
[rest of the components listed on previous list]
Total: €396, or €522 (which is a little too much)
I don't know which processor I want to use, the Ivy Bridge Pentium is fine by me, but others say it's not well suited for gaming. I think the Phenom is a bit outdated since it's from 2009 and the build with this processor is too expensive.
And like the title said, it needs to be a budget build for 500 dollars. So if you guys, the happy little family of pc gaming, could make a list of parts for 500 dollars that'd be great (no Office Space pun intended). The graphics card and power supply are the ones I really want in my system, you guys on the forum can give suggestions for using other components.
Games I want to play are the DayZ mod (soon the standalone version), Planetside 2, BF 3, Fallout series and future games like Bioshock Infinite and/or GTA V (not sure if a 400 dollar PC can handle that).
I'd love to hear your suggestions and tips!
Regards,
Aron from the Netherlands.
