Ok so all i really need is a basic gaming computer to play games that dont really require the best pc ever i mainly play counter strike source, and 1.6 my last computer would play them 50-80 fps on mid settings (it was an acer aspire laptop) global offensive was about 20 fps on lowest settings so wasent playing that at all... anyway i wanted to build a gaming pc that can play counter strike source and global offensive on max settings while streaming with a steady 70-100 fps the cheaper the better but max of $700 dosent even need to be max settings as long as i can play online while streaming with 70-100 fps steady thanks
this is the cheap build i did real quick got it for $477 with the os so i am pretty happy about that but tell me what you guys think about this and if you would change anything to improve game play
Your build is great, except for I would recommend you spend about 50$ more on your graphics card. And for that matter I would recommend a Radeon HD7770 or GTX 650 :) (PS: I recommend that because you might get into more gpu intensive games and I think it would be a great idea just to have that little bit more gpu power.)
Get the knucker keyboard, its the best one under $50 and I have both cherry mx blu and black keyboards, and a knucker, and the knuckee feels almost the same as the mx black. The giganyte isnt bad, but for a $30 keyboard, they knucker is much better imo
Thank you both. Crimson i like that setup there that will definitly be what i go with plus farcry 3 for free why not. Cant wait to get back to pc gaming it's been so long..
