First (AMD) PC build. Need some help pls
Hello,
i need some help to get the right components for my first self build
PC. I dont know if every thing matches to 100% in this build. Maybe you
can tell me? I want to stick with the AMD FX 8350 and the R9 290 and
maybe with the Nanoxia Case cause i like the design and it is German
like i am (explains my grammar ;D). Silence and cooling are a big thing
to me. Long story short can you tell me please if every thing matches
and maybe help me to get it a bit more cheaper (just any kind of hint or advice)
the price is around 1170€).
Components:
CPU: AMD FX-8350
GPU: Radeon R9 290
RAM: 8 GB Kingston HyperX blue DDR3-1600
Motherboard: ASUS M5A97 LE Rev 2.0 AMD 970 So.AM3+
Power Supply: 750W Crosair CX Series Non-Modular 80 + Bronz
Case: Nanoxia Deep Silence 2
Cooling: Arktic Cooling Accelero III Aktive
               Crosair Hydro Series H100i
               Nanoxia Deep Silence NDS 140mm  (4x)
               Nanoxia Deep Silence NDS 120mm  (4x)
Memory: 1000 GB WD Green WD10EZRX 64MB 3.5" SATA 6Gb/s
                120 GB Samsung Evo 840
Thank you for helping me!
And greetings from Germany
Dinggel
Yes all those parts will work together.  I'm in USA so don't know how prices compare in Germany but you can lower the cost by getting a smaller PSU, a good 600W PSU will do the job also unless your using a 4k monitor the R9 280x would be another cost cutting option.
