If i were you i would down grade your CPU from an eight core to a hexa core (FX6300 maybe). simply because while gaming MOST games out there do not utilize all eight cores. I would save a little on the cpu there and spend a little bit more on getting a better GPU. simply because gaming is mostly GPU, i'd recommend the 7850 for $50 more (depending on the deals you can find)
Yeah, if you went with the hexacore, dropped to 8GB of ram, and got a lower wattage PSU (you can get away with 550 watts and be fine), then you could put a lot more money into the GPU.
Also, this cooler is cheaper and will perform better: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103176&Tpk=COOLER%20MASTER%20812
I would stick with what you got, if your budget allows get a 7850 or 70 -they are very nice cards. If not, then downgrade to a Hexacore and/or 8GB RAM. I'd reccomend to stick with a 750W PSU, then you got enough power if you want to add more HDDs or RAM. It's also better to get a more powerful PSU than you need because then it is under less stress and will last longer.
oh, and the corsair liquid coolers really are not that good, go with a noctua nh-d14 or thermalright silver arrow. about the same price, or cheaper than the h60, and better performance, if your case has good ventialtion. besides, you won't have to worry about the pump failing or being loud...
Listen to the others. If you're gonna be gaming for this build, "downgrade" to a Piledriver hexa-core or quad core. You will actually see some improvement(fps) over the octa-core, as game don't know how to utilize it. Then get a 970NB mobo instead. They support Piledriver and are cheaper. Again, if you're just gaming, the SSD is a waste. All you will get are faster boot and loading times. With the money you save get the Radeon 7870. Then if you don't plan to overclock, drop the cooler. If you do, get a Noctua NH-D14( or that other one Gigabuster is suggesting, wonder what's taking him) if you can afford it, or if it's just a moderate bump, get the Cooler Master 212+/Evo.
If you don't want to "downgrade( not really much)" or you're thinking you wan't those CPU and SSD speeds, think about what you are using this for. IMHO, faster boot-ups and loading screens are less desirable than more FPS.
or thermaight silver arrow. and amd stock cooler sucks....
http://pcpartpicker.com/p/mXYa my build, hope you can get some ideas off it
and you will NEVER EVER notice the diff between 60 and 100 fps... anything higher than 60 is probably not even supported by the monitor, and you will not even see any difference
Sweet scorpion platform. I'm too the point to where I won't use anything but AMD, regardless of what people say. I just don't like Intel's prices and I also don't like the fact that they are going to a BGA chips.
But I agree you can downgrade to a FX-6xxx and get a better GPU. You will love it.
