Hey, its my first time on this forum and I would like some help selecting some parts for the new computer I am building. My budjet is $600(Canada $). In part picker it will say $750, but that is because of $175 of other stuff(mouse, monitor, etc.
Part picker : http://pcpartpicker.com/user/N0seBone/saved/3sXl
Could you please tell me if the parts are compatible and if I should change anything. I will be playing tf2, minecraft, skyrim, guns of icarus, kerbal space program, maybe LoL and other games in the future. All I would like is 60fps in 1080p. I also plan on upgrading the cpu to and maybe add another 260x once I have the money. Can I run crossfire and is it worth it?
Thanks in advance :)
Here´s a better and cheaper build ( Quite similar):
http://pcpartpicker.com/user/oscisw888/saved/3t6p
This is Austin Evans $600 build.. (USD)
www.youtube.com/watch?v=SfGE4i_A6E4
You could add a A-Data 60GB SSD for your OS and maybe fit Kerbal on there.
hmmm... with the money saved, think I should buy a i5 3350? And what does the "P" stand for?
When looking initially for parts, I watched this video. Its great and everything I want, but the only problem is parts are more expensive in Canada. Ex. $200 270x = $230 CND, $90 HDD = $100 CND. Wow, you guys down there have it good, my estimate in CND for that computer is at least $700. Thanks anyways
Well from what i know the P means that it has no integrated graphics, which you wont need with a videocard anyway.
If you look on Austin Evans's YouTube, He has builds for USD500 which should be the same.
As for "Wow, you guys down there have it good," I live in Singapore where the only place to buy PC parts is really overpriced and you are probably going to get scammed in the process of buying the parts.
With this budget, it's not worth it. I recommend i5s only to the small system builders and ones with big budgets.
