Finland build for a fellow member
another member emailed me because for some reason he can't make a new forum topic, so I'm doing it for him.  Despite being skilled at hardware and computers in general I ironically can't half assed use Email, yeah laugh it up anyways for people who want to voice their opinion on this here it goes
I'll work on this build myself tomorrow if I have time, I'm moving sunday so I don't know from here is him/her
I'm not buying these from neweeg, I just looked at the parts there because I'm from finland and I'm ordering parts from germany and I wanted to make it easier for you to help me
sorry my English might be bad :D
here are the links
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125439
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147163
http://www.newegg.com/Product/ProductList.aspx?Submit=Suggested&Description=13-157
I could not find my CPU cooler on newegg but it was Thermalright True Spirit 120
--Here is the German websites link to it:
http://www.mindfactory.de/product_info.php/info/p764165_Thermalright-True-Spirit-120.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148834I
I could not find my power supply neither but it was a 550w Super Flower Golden Green PRO Non-Modular 80+ Gold
--German
http://www.mindfactory.de/product_info.php/info/p688894_550-Watt-Super-Flower-Golden-Green-PRO-Non-Modular-80--Gold.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104262if
This looks good but one or two parts need slight changes if you wouldn't mind to recommend me new parts for trade with slight expense change (My budget was 1200E and the build cost E 1.000,47 and has Case included
oh gawd I pasted it from the email and it was terrible and I tried to fix it and its STILL terrible, I told you I hate email
fixing it in word pad was no avail
manually typed it and fixed
gigabusterEXE
thanks for posting this here.
my goal is to order parts monday so I will read this topic as the last thing before i send my order
I kinda wan't this computer fast as my old one has died slowly for months and i think this is the last moment of it's life
alright this is what I come up with assuming they have shipping included in the price, if not then I'll have to changet it, probably go down on the ram and CPU cooler a bit if nessisary
CPU
Mobo
Ram
GPU
Heatsink
SSD
HDD
PSU
Case
this side gives components cheaper and i found them all here    saves about  40€ and i get cd drive on top of it
https://www.mindfactory.de/shopping_cart.php/basket_action/load_basket_extern/id/e957272200dcd733dca54d50d7aea9dea99547e1d37631dfa2e
your site didin't have HDD card on sell anymore or something as i could not add it in the cart
so if you could look did i pick right ones and the money is not the proplem as long as computer stays 1200€ at max i dont die of hunger if i need to pay few euros for shipping
the thing whit case is that german companys will charge about 30 € extra for shipping because of the size of the package so i will order case from finland and save about 20 € by doing so
so i think this is the one you recommended
http://www.jimms.fi/tuote/VL80001W2Z
here is the case selection from 32€ to 60€ for the site i will order the case from
http://www.jimms.fi/hae/g/518/v/0/min/32/max/60//order/price/desc
if you wount look any other case i will pick the one u alredy recommended
Thanks this has been already really helpful
PS.do i need to buy any wires or does the packages have enough
I looked and the thematake is the best one, sata cables come with the mother board, they usually pack 3-6
change out the GPU with this one has higher clocks and is cheaper
http://www.mindfactory.de/product_info.php/info/p810473_3072MB-Gigabyte-Radeon-HD-7970-GHz-Edition-Aktiv-PCIe-3-0-x16--Retail-.html
change out the Frio cooler with this one, they didn't have it on the other site
http://www.mindfactory.de/product_info.php/info/p805673_CoolerMaster-Kuehler-TPC-800-775-1155-1366-2011-retail.html
and attach these fans to it, it will work better than any closed loop water cooling solution
http://www.mindfactory.de/product_info.php/info/p801712_Corsair-Cooling-Fan-SP120-Quiet-Edition-TWIN-PACK.html
If you ever want to spruce up your case all fancy like put a couple of these in there, but leave the Cosair fans on the heatsink cooler
http://www.mindfactory.de/Hardware/Kuehlung+Luft/Gehaeuseluefter/Gehaeuseluefter+120mm.html/1/34327
ok, I upgraded my shopping cart with these parts
only two questions for the fans / cooler
1. is that cooler hard to connect whit the fans (can i hande it whit my skills to plug in lego blocks)
2.should i get extra fans for case or did case have enough
sorry that I ask so much
and thanks you're the best
oops
i missed a line and now i saw the link to fans
but still should i get the extra fans on case i want it to stay cool but i dont want it to make noise for nothing
as for the fans with the cooler, there are black plasitic clips you screw onto the fan, then you take the fan and clip on to the cooler
heres the order you want to do it
put CPU in Mobo install ram in the furthest slots that are dual channel(refer to your instruction manual of the mobo)>put paste on CPU>attach CPU cooler to mobo/backplate (it comes with instructions)>attach fans to cooler>put mobo in case>everything else
the case has one rear exhaust that I know of, maybe one front intake, you can get more fans for it if you want, you have one of the best CPU coolers besides the phantek one, so you should be pretty good even without extra fans, but more fans would not hurt at all, you can always get them later on, its not something that will prevent the machine from running
no problem, ask about as much stuff as you want, I'm here to help make this your most awesome build yet
