Finishing Build
Ok so after months of thinking, ive finally decided to pull the trigger and started buying parts. Ive bought the Ram, motherboard, hard drive, and graphics card. All I need is the CPU, Case, and power supply.
I saw this power supply and thought it would be pretty good for the price, btw it needs to be at least 550w
http://ncix.com/products/?sku=59615&vpn=P1550SXXB9&manufacture=XFX&promoid=1033
I only have about $190 left before taxes & shipping. Im happy with an i3 for now and would like a decent case(I was thinking about the corsair c70)
If you're curious about the parts I've already bought here you go.
http://pcpartpicker.com/p/uyPY
Yeah, I would go with an i3, that PSU is a great deal if you don't mind the unmodularity (if that isn't a word it should be), XFX is a reliable brand. So then that comes out to a 30$ case.... you won't be able to afford a C70. If you can scrape a bit more money then you could afford a bitfenix shinobi (my first build was in this case and it was amzing).
Alright, thanks for the comment
The <$100 cases from Bitfenix have $100+ features and sacrifice very little to make that happen.  ie. Bitfenix Shinobi
Usually NCIX has the Antec P280 for under $90, that's also a great case to get in that price range.
