[Finished] Another pfSense build
Background:
I'm ready to replace overpowered pfSense rig (my previous gaming rig).
It too much power and heats up the room. Now that summer is approaching, I don't need this extra heater and I want to replace with something lower power and quiet.
Requirements:
Reusable parts (what I already have for a build):
Please recommend parts!!!
  • If you want fanless, just go embedded
  • Find cheap old crap on ebay
  • Make future-proof build with new mini-itx
0voters
Votes are public.
Best I could come up with in short time of research. Check out 8GB crucial dimm with combo and a little bit cheaper than the pfsense version.
Once I do testing on the Up² as a router, I'll let you know how it performs. Base model is half the price of the embedded solution you listed. It should work well. It does have a fan, but you can't hear it. It uses such a low-power SoC that if you really need it to be fanless, just stack a larger heatsink on it. power consumption under load, I figure to be around 5-10W if you connect no peripherals.
One alternative is finding an Atom-based machine or something based on an AMD E-series CPU. Those will run you a lot less than $150, especially considering you have a lot of the other parts you need. Slightly higher power consumption for sure, but far below 70W.
This one doesn't have a fan.
I got an old amd e-300 it worked well for me with a dual gigabit intel nic.
These look great!
My parts should fit into this build well.
Will these tiny processors have enough juice? They shouldn't be a bottleneck, right?
from looking at the old video Tek Syndicate did back in the day, they introduced very briefly an ALIX box which runs off an AMD Geode processor, so I imagine if that can push gigabit, an E-350 should be able to as well, but I don't actually know.
I looked up the Alix boards and they are only 10/100.
These the atom processor boards?
(wait, that has regular PCI slot so my nic wouldn't work.)
:confused: 10/100, that... kinda... sucks...
in that case, I don't know.
Also, yeah, those are the atom boards. They're pretty dated, so that's why I lean towards the AMD boards, but I haven't used one. my last router used a 1.86GHz Core 2 Quad, so...
I guess an atom is enough....
An atom is enough for most things, on a high traffic connection it may not cut it, or high bandwidth vpn traffic, that sort of thing.
Update:
Got the new Asus E35M1-I mobo swapped in. The change went off without a hitch! No need to reinstall or anything! (I love linux)
My power usage went from 108 watts to just around 35 watts. It's also fanless now so it's muy quite.
@KemoKa73, thanks for the recommendation on this mobo!
I should have gotten that build because of this:
https://www.netgate.com/blog/more-on-aes-ni.html
To future proof your builds, get CPUs that support AES-NI.
I bought one of those j1900 based builds- Its nice, I like it, but its not going to be able to update as new pfsense versions come along.
wow, that's really good to know!
That sucks though cause to have peace of mind you'll need to upgrade...
