Finding The Perfect PC Case
So Ive been looking all over for cases that fit my needs with very little sucsess. Preferably, i want a case that is less than or up to 30cm in depth, and if possible, atx or mini atx. I really liked the look of Apevia's Master-BL/500 (unfortunately too deep) and also the Bitfenix's Prodigy (which would force me to buy a new slimmer gpu, processor and mobo as i sport a LGA 2011).
Does anyone have any advice for me? I was even contemplating just getting some aluminum sheets and making a box myself that perfectly fits in my bookcase..
Despite being a full tower case, the NZXT Phantom (http://www.newegg.com/Product/Product.aspx?Item=N82E16811146074) is only 22cm deep, so this one will fit.  It's also got amazing airflow, and can support up to 3 200mm fans!
If you want a mid tower, the Phantom 410 will also fit, as well as the Cooler Master Haf 912, Haf 922, and Haf XM.  My recommendation would be the Phantom (the bigger one!) though either of these cases will work.
CM Haf 912
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
CM Haf 922
http://www.newegg.com/Product/Product.aspx?Item=11-119-197&Tpk=11-119-197
CM Haf XM
http://www.newegg.com/Product/Product.aspx?Item=11-119-257&Tpk=11-119-257
NZXT Phantom 410
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146085
I really enjoy my corsair c70 in white. Very good cable managment and fan options. I think it can have up to 10 fans in it or something like that. It also has a nice look to it, and its not to big. Also if your trying to fit your PC in a bookcase I wouldnt really recommened it. You will have trouble with heat due to venting issues.
