Similar yes. Double coil but these coils are optimized for the 5/8th lambda not the typical quarter wave… A little differences here and there to make them equally good at transmitting as they are at rxing… Typically people buy antennas to improve gain but theres so much more you gotta do with the new tech… (especially AX> You might as well stick to stock with AX. The explanation is long and will muck up this thread so I wont get into it)
The spread is wonderful. the antennas can be software configured depending on the channel width. If you have 80x80 to make 160 its a 2x2 if you have just 80 its full array. (openwrt). I talked about why this router is awesome here. Also talked about the properties of my antennas
Scroll to the middle of my OP blog post also table of contents
Anyways OP… any AX router will do. You can find higher end for cheap on Ebay. No sense paying full price. Sometimes Ill buy a bricked one (super cheap) and jtag it but if you arent comfortable with that just stick with confirmed working open box’s
AX is still heavily evolving. I would wait until its through a couple of waves before buying.
