but i dont know if i could affordably do that, i would love some critiquing like always, and i know that i should reconsider my case, but for the whole deal that package on newegg looks awesome
mine isn't modular, its <80% effecient, yours is up to 90% effecient, same Amp and watt rating, you really only need a 650w but an extra 100w for the future won't hurt
you can get the OS, Case cheaper on Amazon like your PC part picker said, also you need to login and apply the PromoCode
you won't need a mouse pad or anti static strap, just ground yourself on the case every so often, the ADATA SSD is faster, you will not need the HX PSU go with the one I showed you, my heatsink with those Fans performs as good as the H100 if not better, my GPU is significantly better, and with unlocked Overclocking, you can install windows with a flash drive its a bit quicker that way too, eleminating the need for a Optical drive
ok, now the non modular psu, will i be dealing with like a ridiculous amount of cables? and will i have enough cables? i think that the h100 with 4 fans is a great option, and i really would rather not have a huge heatsink. but if they truly get better temps and is a cheaper buy i couldnt ignore that.
you'll have enought cables either way, if you can get the Hx for 99 get it, modular is nice, you'll still have to do cable management, just like 2-3 cables less to deal with
now your thoughts on GPU? the one you reccommended is 500 dollars and the one i have now is 400. so, for the extra hundred the msi may be great but i really want a 670 not a 7970. I'd thinking about the ASUS Direct CU ii TOP 670. Y/N?
