I've been looking round at Combinations and Cases i like and i have finally came up with a build thanks to copperman In the way of finding my pc this is what i've got
You are in the UK and you spelt finalising with a 'z'! Tsk tsk!
Two questions:
1) How sure are you that you want to go Intel? In that price range you could get an AMD with a lot more cores - the way games are going this will make a measurable difference.
2) Why 6gb of ram in three dimms? It is always better to go in multiples of two with your dimms. Get either two 2gb dimms or two 4gb dimms.
I just wanted an Intel CPU, I don't know how to Match amd cpu with mobo because they always seem the same price as an intel when i do it and X4 965 is really good my friend got 1 and says he only needs to only update his gpu after 2 years of having it
Give some suggestions About AMD CPU's and Mobo Combo's budget for that is £150-160
With an FX-6300 that machine will fly compared to an i3 - and for a couple of years for sure.
I have an FX-6300 based machine with a small overclock (4ghz) and a weaker gpu than yours (I have a GTX 560Ti) and I can run virtually any game on high or ultra at 1080p.
If u want to stick with intel then get a 650ti boost and a i5 3570k or 2500k. If u want amd (which will get u a better system, get an fx8350 and a 7870
