Before I buy this rig I would like to make sure that there is no compatibilty problems between all of the hardware components :)
This is the rig : http://uk.pcpartpicker.com/user/robjenno97/saved/2eFD
Thanks :P
Thanks :P
Think you're pretty bang on with your choices. I would swap the MSI motherboard for either an ASUS or Gigabyte.
http://uk.pcpartpicker.com/part/asus-motherboard-m5a97ler20
http://uk.pcpartpicker.com/part/gigabyte-motherboard-ga970ads3
Then you've got the best system for your budget.
Okay thanks for the help :)
Fan looks tall, i'd check for clearance issues with the case. Case is 19 cm deep, fan is 13.5. Once adding in the stand offs, another cm or 2 of space so it doesnt touch the case, and the socket brackets I can't tell you for certain.
what do you think of the asrock 970 extreme3 board? :P
I have checked on the internet, and people with this fan and case seem to not have problems :P
Decided to use the asus M5A97 R2.0 board instead :P
Yeah its an ok board i have it
yeah, the reviews for it seem pretty decent
