finally getting around to building my first pc,
any final thoughts? anything i'm missing? (besides os)
http://pcpartpicker.com/p/yKBMTW
HDD?
And do take a look at the compatibility notes at the bottom of your link. Havent used that case before,so i'm unsure if the cages can be removed
The Hyper 212 is a tight fit in the Source 210. I would recommend finding a larger case, such as the Corsair 200R to advoid any problems of the Hyper 212 not fitting.
And yeah, you're missing a storage device.
whoops, forgot to mention that i already have a hdd and ssd to go along with it, and thanks, i changed the case
http://pcpartpicker.com/p/WdgVGX Uped the processor to an 8 core for more processing power. Uped the mobo to accommodate the 8320's power needs. Also swapped the 760 for a R9 280x because the R9 280x is closer to the Gtx 770 in performance. Lastly used a pcie wifi card because usb ones are usually very unreliable.
