I made about 3 posts requesting help but now, this is the last since i found the perfect place to buy all my parts. If possible, I want windows 7 home premium in this build. But if there isnt that much difference with a fake copy and an original one and also if the fake copy is as stable as an original one then iill fake that $hit lol. Thanks for reading guys. (I hope you're reading this lunyone hahahahaha)
pricelist:
https://ftf-280.yousendit.com/download/1/2E040FEB2FB8C3B9/59a9bcb4b3466fe62890b1e8adfad5dcb8830be8/5-3-13-new-long_srp%20price.pdf?download_id=4338782284&user_locale=en&id=1900568932&ufid=2E040FEB2FB8C3B9&file=5-3-13-new-long_srp%20price.pdf
I cant buy online so im buying from a local store. This is the best store i can find with honest pricelists. I hope you guys help me. Thanks. :)
I forgot to say that this is going to be a gaming rig. (BF3, Crysis 3, Farcry 3, etc.)
I cant buy online. This is the only place thats good enough for me to buy. Pcx.com.ph is their website but its not retail price. :(
ok then, for a 550$ you can get a hd 7850(overclocked) or a gtx 650 ti boost for around 180 bucks(+-). if you're big on intel, get an i5 2500k. if you're budget oriented, an fx 6100-6300 should suffice. for the intel, get a mobo with a lga 1155 socket. ask around for a h77 or z77 mobo if they're cheap enough... the h77 will set you back around $105 (that's the price where i live, which is in Indonesia). asus m5a99fx r2.0, gigabyte 970a-ud3, or the asrock 970 extreme4 for the amd... those will set you back around 85 bucks... chose your own psu, a 600 watt 80+ bronze will cut it. ask your store for either a 4 gb ram or 8 gb, depends on the price. the case? silverstone precision PS08 or any case you get for under $50. add another $50 to your budget if your $550 is not enough...
Get 8Gb of ram, 600+ Watt Bronze plus psu.
970 motherboard.
AMD 6300 or 8350 cpu.
7850.
NZXT Source 210 case
Cooler master hyper 212 evo cooler
