Final opinions on first gaming rig
Sorry for all the posts but just want to get it right. My budget is $950. Any opinions and comments would be greatly apperciated.
http://pcpartpicker.com/user/TimmyTimTim/saved/1tlP
Pretty good build you got there but just one thing, if you ca swing the ASRock extreme 4 go for it because it's alittle more loaded for alittle more. But if you can't fit in your budget don't because the extreme 3 is fine and maybe consider the havik 140mm for a cooler.
I really dont want to spend any more money. Im a highschooler on a budget. :)
I got the same situation, and me not knowing much about computers compared to some of the people on here, I kinda like this setup. The 8350 is pretty good for the money though. AND it should come out to about a grand with your OS, not bad if I might say myself.
