Final build
So after 2 weeks looking for good parts I have finally decided which parts for my PC I will get
http://pcpartpicker.com/p/2gFO8
 I would like to you guys reccumend me some changes if nedeed.. and I would like to ask you if I should wait for GTX 780 Ti to get cheaper and then get one or I should just get two of those GTX 770?
Are you going to be using the stock Intel cooler?
I just built my friend a pc with a single 770 in it. Its a damn good card. Either way will be a great option.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133524
/thread
No I will be gettin H100i after sometime when I get enough money. Because I will OC i5
