***final build***
First of all, i'd like to thank everyone that told me what to do and what not to do. You guys are heroes.
This will be my FIRST PC BUILD.
here's the part list: http://pcpartpicker.com/p/18FLa
I already have a mouse, and a 24 inch tv i will be using as a monitor. I also have a speaker system.
Are there any last suggestions? any comments on my build? please feel free to voice your concerns.
again, thanks to all the unsung heroes who helped me greatly, you know who you are.
i got everything from newegg because i'm using my mom's credit card and she only wants to order from 1 place.
I'm fairly solid on how to put everything together once i get my shipment, however i am terrified that i will forget to purchase something and i will be unable to build it. please help ._.
once again, thank you for your time and thank you for commenting and helping me. i'm a little nervous but i feel confident you guys will point me in the right direction.
Also, i will be using this build as mostly a gaming engine.
battlefield 4, hawken. awesome shit like that. i can't wait to enter the pc gaming world.
I was wondering if i should grab this MOBO instead of the micro atx. my case supports full atx, and i'm probably going to crossfire later on, which isn't supported by the micro atx.   http://pcpartpicker.com/part/asrock-motherboard-990fxextreme4
If you can get that motherboard that would be better but you would be better off getting a 7850 2gb or 7870 or gtx 660 or somthing instead of the motherboard for better gaming performace.
http://pcpartpicker.com/p/18O7X
http://pcpartpicker.com/p/18OdK
Not sure what your budget is.
Can't i just get the motherboard and then buy the same GPU and crossfire them? these builds you guys gave me are a little out of my budget.
i need to keep the price as low as possible right now, but i want the switch motherboards so i can crossfire later.
HELPPPPP
Why crossfire just get a beter singal gpu or do you just wana save up and make that esay upgrad later
