Final build
after weeks of research I've come up with this build. And some major tweaks im pretty dang satisfied. Gonna pull the trigger tmrw. Any last minute suggestions?
http://pcpartpicker.com/p/GuGQ
Thanks Vinn
You are only drawing 500W, but you have bought a 1050W Power Supply. The ONLY Way to get close to 1050W is if you are Quad-Firing 4 7970's. Also if you are not overclocking the CPU to beyond 4GHZ, get a cheaper ASRock mobo.
I plan to add a second graphics card and over clock so I was future proofing it some
