Final Build Revision Check
How does this configuration look for gaming? Won't be doing much rendering/video and photo editing.
http://pcpartpicker.com/p/NPJP
I already have a Kraken X60
Its would look great for a rendering Rig, for gaming not so much
for the Price your Paying id get one of these
http://pcpartpicker.com/p/NPQ4 <- Intel Build
http://pcpartpicker.com/p/NPRP <-AMD Build
Although with a Budget like that you could probably get a 3770K if you wanted, wont see much if any improvement from the 3570K in gaming though, but if you do any kind of rendering or plan on rendering sometime in the future it will be a beast.
 I have heard bad things about the cooling on gigabyte cards, I would go with a sapphire instead.
I'll go with the AMD rig and a Sapphire Vapor-X
BeyondNight, which would be a beast for rendering, the i5 or the 8350?
Using what software to render?
the I5 when at the same clocks as the 8350 will beat it, Plus the IGPU and better Memory bandwidth of the i5 will help out for larger tasks.
What did you hear that was so bad about it ?
