So yeah, basically i just bought the game from gog and installed it. but everytime i run it my monitor says no signal. yet, i can hear the games main menu.
Any help is very much appreciated
and no im not using intel graphics
Maybe it's running at a higher res than your monitor supports?
http://pcgamingwiki.com/wiki/Fez
Maybe try starting in windowed mode.
This is from the above link:
Change the resolution/screen mode
Settings" found in the game data directory.Thanks bro this did the trick. my monitor is 1360x768 so it would support the 720 but for some reason it will only play in windowed mode...wonder why that is. but it works now so thanks a ton
